winbox for android
Is there Winbox program for Android phones? and does it work as windows winbox or extra setting need to be added in Mikrotik to make it work?
if you are using android so you can access your router in Webfig . Webfig i also like a same winbox . Just go to android browser & Type your router ip address & login to Webfig .
