Winbox freezes on DHCP Server window
We have an RB493G router with 6.2 on it right now. Somewhere along the road something happened to it and anytime we bring up the DHCP server window, winbox crashes. It started in 5.x and we kept upgrading the firmware thinking it might go away, but no help.
We can access the DHCP server settings just fine over command line.
Anyone encountered this? Any tips on what to look for?
strange problem!! will you check, what is the % of bad sector in your router storage? if command line works fine, then winbox access also should be OK.
