Winbox fulscreen issues
Not sure if this is correct spot, but I am having issues when connecting to my RB750G running 5.8RC. Here is a screen shot showing what it looks like.
ROS Ver: 5 RC8
WinBox Version: 2.2.18
It seems to only happen when connecting to ROS 5 boxes.
I have tried clearing the cache via winbox and manually.
Also tried w/ w/o secure and “load last session”
I get the same problem. Right click the grey space between the windows task bar the and menu on the left and add a gauge (any gauge), and it expands to use the full window size.
Hey fewi: What exactly do you mean by “add a gauge”
Right click the empty gray space between the Windows title bar (“admin@66.78.100.108”) and the menu on the left (the “Interfaces” button). You get a menu that says “Add CPU”, “Add Memory”, and “Add uptime”. Those are little gauges that show resource information in that space. Adding a gauge or removing a gauge resizes the window correctly.
If that’s still unclear I can post a screenshot.
I got it now. Thanks again fewi.
Whats this? Maybe this is your problem, some plugin?
Normis: That is from a screen sharing / remote support program I use called TeamViewer. It can allow you so share an app remotely (among other things).
I have tried with and without, but so far today it is working both ways.
Yes!
It IS TeamViewer causing the issue. TeamViewer > Options > Advanced > QuickConnect > Configure.. > Add winbox.exe as an application not to run QuickConnect for.
Solves the problem immediately.
Excellent find guys.
EDIT : Submitted to TeamViewer as bug.
