Winbox gives ERROR connecting to G-52HPACN
I keep getting an ERROR: could not connect to 192.168.88.1 while trying to connect G-52HPACN with Winbox. I tried changing IP address manually I tried connecting the device with cable to the laptop and to the ASUS router and tried to connect to it threw WIFI but everything was hopeless I’m so tired of it all. please help. and thanks in advance
Please Advice about the winbox ERRORS and G-52HPACN connecting problems in general. Which faced you the experts during times and fixing them.
hi all I did not get any reply from anyone. please advice as I bought the device and cannot use it for how many days now.
If you demand support, please check out https://mikrotik.com/support:
  1. If you have bought a RouterOS license or a RouterBOARD product, limited support service might be provided by e-mail for 30 days after the purchase by > support@mikrotik.com> . Contact your distributor for help and support, if device is not purchased from MikroTik directly.
Nevertheless, try contacting via mac address (just click the mac column in neighbor tab). If that doesn’t work, reset the device by following the procedure as outlined in the quick guide:
Hold the reset button during boot time until LED light starts flashing, release the button to reset RouterOS configuration (total 5 seconds).
And immediately upgrade your device whenever possible because of this issue: https://blog.mikrotik.com/security/winbox-vulnerability.html
