Winbox GROUP function
Hi Forum,
Hoping to hear from the devs - but is there any plan to fix winbox’s ‘GROUP’ function? i.e. When you assigned save profiles to a GROUP, then you sort by Group it used to sort by the whole group - looks like now it only sorts by first letter of the group (which means that Groups starting with the same letter are mixed in)
I’d really like to go back to the old way, is this a winbox issue? Or is my local db screwed up causing this? I’ve tried on the latest 3.16 winbox.
Thanks,
Joe
