goddy
March 16, 2005, 3:01pm
1
But you guys am not saying I know thing about this.All I need was how to get around with:with the winbox or OS itself and I can configure it myself.
For instance,when I try download winbox,I get 'the page cant be displayed" and when I use the router os, I can get the id in.
so basically that’s it.I can configure myself but I need a push
onubah
March 16, 2005, 3:12pm
2
Goddy, first give me a picture of what you want I can give you clue on how to do it.
I am also new, but I managed to get my working so I can tell you how I did it.
Basically from Gateway (RG) to Switch - to - AP and clients connect from that point.
So how do you want it?
Paul
goddy
March 16, 2005, 3:51pm
3
Hi
I have omin,ap and 2 clients,I have been able to mount them,now do I use the winbox or the linux based OS to configure.
what do u propose?
goddy:
Hi
what do u propose?
The Winbox is nothing but a Graphical Interface for RouterOS (where you can do pretty much the same as in a Telnet/SSH/Serial session with RouterOS) running on Windows (and Linux using Wine).
You can probably use both, but most people prefer using SSH to connect. I use both Winbox and SSH - depending on what I’m going to do. To make a quick error search I normally use Winbox, but I use SSH when I configure the units.
goddy
March 16, 2005, 8:14pm
5
hi,
I have tried to follow the link( http://<router_address) but any time,I get this:the page can not be displayed
what do i do?
You can check if the service actually is running:
/ip service
goddy
March 16, 2005, 8:33pm
7
what ip service are u talking about?
look for the “www” service, it should be on port 80 or 8081 if you set up hotspot.
normis
March 17, 2005, 7:03am
9
actually, first check if in your router, the interfaces are enabled and the IP addresses are assigned correctly. follow the basic setup guide to learn how to connect to the router and how to set it up:
http://www.mikrotik.com/docs/ros/2.8/guide/basic
normis:
Yeah if its a new install or if you reset the MT to default configs then all interfaces are disabled and you have to serial into the router.
normis
March 17, 2005, 7:11am
11
as far as i understand, he just got his equipment
goddy
March 17, 2005, 10:18am
12
HI,
AM NOW CONNECTED TO THE ROUTER THRU THE SERIAL,WHAT NEXT?
normis
March 17, 2005, 10:21am
13
follow this help file to set up interfaces and addresses or simply run setup command. http://www.mikrotik.com/docs/ros/2.8/guide/basic
goddy
March 17, 2005, 10:38am
14
HI,
I UNDERSTAND YOU,BUT AT THIS POINT CAN I USE THE WINBOX OR ITS NOT NEEDED
2.OR I SET A DEDICATED PC?
normis
March 17, 2005, 11:11am
15
FIRST please use the setup command to set up your interfaces and addresses. from the serial console please
