WinBox in EVE-NG
Hi all,
I have EVE-NG and I configured on ESXI this lab. How I can to configure all my Mikrotik device in lab through WinBox and not CLI. For me is very hard to configure through CLI. Can I integrate this app WinBox in EVE-NG ?
Thanks in advance.
You can create a TAP interface in your Host, attach one of your Guest RouterOS interfaces to that TAP interface. Now, your Host should ‘see’ your Guest and, if WinBox is installed in Host, you could configure your Guest using WinBox.
You should just be able to connect a “Network” that is associated with your Management network. Similar to adding a node, you can just connect to MikroTik to the management bridge and you will be able to pick it up via Winbox on your actual machine that is running EVE-NG
