i faced an annoying issue in winbox for v3rX , its not saving the windows setting , each time i added somthing from the show column field , i have to add it again next time i enter this window !!!
example : in simple queue window the default hasnt TX, Rx .. so i need to add it from show column , each time i enter the winbox i have to add Tx,Rx again !!!
Ya Sam you are right, I’m facing the same problem.
Ditto. It would be great to get this fixed. Aside from that, RC9 seems good so far…
well , RC9 seems so good , its working now for 15 hour with web-proxy enabled , no FREEEEZING , let’s wait more than 24hour and see ![]()
after 1 day , it’s freezing again !!!
same problem here Sam its freezing after 2 days here and when I reboot the sys every thing work well ![]()
I dont know whts RC means ? is it different than BETA ? is it hard to solve this problem ?
RC= Release Candidate
exacty what is freezing and what happens when it is freezed, if you can create supout.rif and send it to support when freezing or just been freezed
the whole PC is freezing , no responce to any input (keyboard) , so how can i make supout.rif when its freezing ? i send supout.rif to support , no direct solution except upgrade to higher release candidate !!!
and i dont know when it will start freezing , last time more than 24 hour !!! without enabling web-proxy every thing goes so smooth …
i dont know why MT REMOVE squid from options ? and as in the 2.9 2 proxies , untill everything is working normal ..
Yes I have written so many times about one disadvantage of Ver.3 web proxy and that is we can’t put any max object size on our own in the web proxy setting, that’s why big files like 20 MB can’t be cache. I have tried so many ways to do that but failed. Hope MT OS builder can fix this and give us the chance to put the max object size on your own. ![]()
And let me tell you I can do it with Ver2.9 easyly. ![]()
Regards
yes , its so easy in 2.9 , beside you have 2 options of proxy there , i wonder that things must go better not worse ..
I’ve posted this issue too: http://forum.mikrotik.com/t/winbox-and-show-columns-feature/16756/1
If you exit from WinBox through “exit”, you loose your “columns” settings
You mus exit from your winbox session closing winbox’s window instead click on “exit”.
(you can use this “method” until WinBox developers fix this issue)
regards.
Andres
omg, somebody uses “exit” button? =)
ha ha ha ha …! ![]()
wow, I have nearly 600 mikrotik devices in the field, I spend 1-2 hours a day on average logged into winbox, and I never realized there is a button other then the windows X to exit winbox…
hehe, I just clicked it, and guess what, it exited!
now I have to log back on, I didn’t actually need to close, I just wanted to hit the button ![]()
ive had many times where the ‘exit’ button is the only way to save settings. Hitting the X wouldnt save window positions, settings, etc in winbox. Some of you say its the other way around ? Anyhow, X and EXIT should do the same thing in my opinion (hint hint winbox creator).
hmmm… ‘X’ always saves windows positions for me…
yes, both X and Exit save your settings. Make sure you don’t have the “load previous session” unchecked in the loader ![]()
