Anybody using CrossOver to run Winbox on macOS Sierra? (If not, how are you use Winbox?)
I can’t see IPv6 address of my router in Winbox neighbor table. IPv4 is ok.
Thanks a lot.
Thanks a lot.
I don’t use Winbox much on Mac, but I just tried with Wine Bottle.
IPv4 works, IPv6 does not.
It says “ERROR: Invalid address - ”
Thanks for your feedback. I’ll try another solution.
For what it’s worth, Wine that is packaged with Fedora 26 works without a problem for both IPv4 and IPv6.
It’s possible Crossover isn’t compiled with IPv6 support.
That said you can always bridge a VM to your WiFi or Ethernet interface and run it on Windows proper.
Thinking on this way too. However, I mailed CrossOver Team asking an info.
Thanks! ![]()
