Winbox is deleting my Addresses
Has anybody run into an issue with Winbox deleting their Addresses? When I open a dated back up the addresses are there but on subsequent launches of Winbox there no addresses. Discovery tap shows my close routers ok. I running Winbox 3.40 and version 3.39 was having this same issue.
Let’s start off with what router, what router software version, and confirm you mean in IP > Addresses? If that is the case, no - never seen that problem.
Are the addresses in question static or dynamically assigned?
If we get very far, you will need to post your configuration, so to avoid the rush, please post your configuration. To export and paste your configuration (and I’m assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) “/export hide-sensitive file=any-filename-you-wish”. Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
