Is it possible to run 2 instances of winbox at the same time, each with their own address list or any kind of workaround ? (windoows OS)
you can certainly run multiple instance of winbox but I’ve always done it from the same folder so they would load the same address list.
I guess if you have two folders for each then they should load whatever is local to them.
I think it would be great idea to run candidates winbox session like candidate config in JunOS. Maybe in ROS 7.0
When you save an address you have the option to enter a Group, can you not separate them by group then use the filter on the right to choose only the group you need? Does what you are asking in a single instance with no “workarounds” needed.
Maybe this wil help you: (cli)
Description of menu items in loader screen
– File
New - Create new managed router list in specified location
Open - Open managed router list file
Save As - Save current managed router list to file
Exit - Exit Winbox loader
Found here: https://wiki.mikrotik.com/wiki/Manual:Winbox
