Winbox Issue
Hello
I have RB 333 with Ros3.23 and when i connect using winbox the router disconnect at the moment i log in, and i reboot the unit the same issue happen.
Do you use IP Winbox ?
Have you tried SSH or Telnet to access the board ?
Using, Mac and IP address has the same issue.
What about Telnet, SSH ?
Do you have the latest Winbox version ?
The latest Winbox version is available at http://your_router_IP, when the latest version is installed on the router.
