Hi there,
I’m having a slight issue with winbox on 1 pc. Basically when i load up any router on that pc using winbox and the window for the program is anything smaller than maximum size. I try to maximize it and the new area is all grey’d out. Inorder to get this to show correctly I have to add a current memory/cpu usage bar or uptime bar. Also the redo and undo buttons don’t show up.
I’ve tried re-downloading the program but it’s still having the same issue.
Any suggestions?
