I have strange problems with winbox on my PC (WinXP 2GB RAM) - if I run multiple instances of WinBox the Winbox tend to crash silently (i.e. the application dissapears and no error dialog box is shown) when I try to open a new form (say WiFi configuration dialog or so). In most cases it helps if I close some unused winbox sessions (especially the ones which are already disconnected from radios). Sometimes winbox crashes even only one copy is running. It looks like some memory allocation problem in the application or so. Anybody hs the some problems? It may be related to some memory problem related to WinXP I think.
I have tried to use decompresed winbox (upx -d winbox.exe) to see if there are no UPX/swap related problems but it didn’t help.
I am using the latest winbox I found on http://www.mikrotik.com.
this is not the case. When I lost connectivity for some reason - the Winbox shows error box and the session is terminated after the OK button is pressed. I mean problems related directly to the winbox - not to the remote mikrotik nor the connection to it. If the problem appears it is not possible to establish reliable connection even with lokal (connected by ethernet) MTs. Then is enpough of the Winboxes is terminated I can start new Winbox session again. It looks like there is some problem with memory allocation in Winbox (or perhaps in Windows)… I would expect the Winbox will says something like ‘There is strange problem with memory or with something else and we have to terminate’. But the application disappears silently…
Apparently winbox can be unstable if you connect via the MAC address. So rather use the IP address once it’s set-up.
The latest version, 2.2.13 solves the problem of locating the unit via it’s MAC address and then automatically connects you via the IP address if you click on it.
The problem I have is not related to MAC telnet (connected via IP) But maybe the newer versions of Winbox did something with it. For some time I didn’t see the winbox disappear…
When the problem appear any new session made via Winbox crashes after a while (when I pickup an item from menu, try to see wireless card settings etc).
not yet. It looks I found another problem the checkbox doesn’t remember its settings after Save
Usually the winbox is working fine. The problem usually appears when I left too many winbox sessions open and many of them lost connection to radios. Even active session may have the problem (I select wireless interface settings for example and the winbox terminates silently)
