I have been trying to configure the nexudus hotspot. I did a little bit of work, just enough to create the hotspot, but after that, winbox keeps disconnecting me.
I have tried the following to resolve the problem, but to no avail:
Gotten newest version of winbox – 3.17
Updated the router’s firmware to latest
Reset the router back to factory settings
Tried to use an IP address instead of the MAC address to connect with. This kind of worked until I installed the hotspot again, in which case it stopped connecting using the IP address altogether.
i had something similar with hap ac2, in my case “quick set” opened window was causing disconnection (still don’t know why). as soon as connect i hit ESC to close windows, problem was solved
