I am very new to this forum, so I’m sorry if this on the wrong sub forum. So I recently bought a Groove Ga 52HPacn. I am using Winbox to connect to the device (the device is freshly reset).
I am able to get the mac address on the Winbox but the IP address on the winbox of the device is 0.0.0.0. So I thought I can configure this inside the Winbox. So when I connect to the device, it connects perfectly but within 4-5 seconds it disconnects. This keeps happening. I have reset the device multiple times. But the problem persists. I cannot even use webconfig because I don’t know the IP address. If anyone can guide me with this. It would be helpful
I am currently using WinBox v3.17, I suppose this is the latest version and according to update release this version should actually solve the bug of disconnecting. But this bug is still there. I’d appreciate greatly if anyone can help me solve my problem.
In my case “quick set” opened window was causing disconnection.
As soon as connect I hit “ESC” key to close windows opened in WINBOX, PROBLEM was solved
For me it was the router IP was in outer range of the dhcp leased IP.
For eg DHCP lease IP were 192.168.88.10 to 192.168.88.254.
My router IP was 192.168.88.1.
I change my router IP from 192.168.88.11, (that is the IP is inside the range of DHCP lease), the frequent disconnect was not there.
Try using webfig to configure these setting.
I experience this issue anytime I try to connect to a device using the MAC Address. This is incredibly frustrating since the disconnect happens faster than I am able to perform any changes on the device. This has been consistent for me on both 4011 and 2011’s as well as the Hex’s. I have tried hitting escape. I have tried going into quick set. I try to go through the menu to completely reset the config but I’m not fast enough to do this. I have tried manually resetting on the 2011’s screen but it keeps the default config.
My main issue is that I am trying to configure new routers that are connected to an existing 4011 with the default IP scheme. It automatically conflicts with the default config and I’m unable to connect via IP. I thought this is what connecting via MAC was designed for but this seems like a useless feature if it only allows connection for a few seconds. Does anyone have any advice that is not changing the default IP scheme on the main router?
--------------------------------- EDIT -----------------------------------
I was able to use the MAC Telnet from the main 4011 and telnet into the 2011 that was giving me issues. Doing it this way I am able to remove the default configuration and setup an initial configuration that will allow me to connect via winbox. I wanted to update my post with this work-around. Note that this will only work if connecting through another mikrotik device. I am still looking for any information on being able to use the MAC Address connect in winbox without it constantly disconnecting.
