winbox keyboard commands
What do you think about letter commands in winbox?
  • It’s fine to use only letter
  • I want to use safer combination with “Alt” key
0 voters
I’m just firstly trying v3.0.
Don’t you think it’s dangerous to press only some letter(“r” or “d”) to execute a command in winbox console?
Is it possible to disable these letter comands or use something like Alt+r instead?
what commands do you mean? examples??
When I’m in Interface list or Address list, any interface or address is selected, now pressing the key “r” will remove it.
Doesn’t matter if I wanted to do it or it was a “fortune”. If it’s my only interface/address which ensures connection on remote site, I’m out.
