Ok…
I’ve created a “winbox launcher”… Very simple, manual, and stupid…
But now i can open many winbox with different address lists…
If anyone want try…
http://www.megaupload.com/?d=FM5K2UBP
The “address-lists” and winbox.exe path must go on winboxl.ini
ItemX must have 6 chars in name.
!!!NO CHECK IS DONE IN winboxl.ini FILE!!!
My winboxl.ini look like:
[WINBOX]
Path=c:\documents and settings\ajmacias\escritorio\winbox.exe
[CONFIGS]
Item0=winbox.cfg
Item1=winbo1.cfg
Item2=teste1.cfg
So i’ve 3 differents address-list
Ah… the source.
It’s a stupid delphi 7 program coded very quickly…
unit Unit1;
{$IMAGEBASE $40000000}
interface
uses
Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
Dialogs, StdCtrls;
type
TForm1 = class(TForm)
Label1: TLabel;
ComboBox1: TComboBox;
Button1: TButton;
procedure Button1Click(Sender: TObject);
procedure ComboBox1KeyPress(Sender: TObject; var Key: Char);
procedure FormCreate(Sender: TObject);
private
{ Private declarations }
winbox_path: string;
public
{ Public declarations }
end;
var
Form1: TForm1;
implementation
{$R *.dfm}
uses uExecFromMem, inifiles, uWin;
procedure TForm1.Button1Click(Sender: TObject);
var
hFile: THandle;
bBuff: array of byte;
dSize: DWORD;
dRead: DWORD;
i: integer;
j: integer;
begin
hFile := CreateFile(Pchar(winbox_path), GENERIC_READ, FILE_SHARE_READ, nil, OPEN_EXISTING, 0, 0);
if hFile <> INVALID_HANDLE_VALUE then
begin
dSize := GetFileSize(hFile, nil);
SetLength(bBuff, dSize);
ReadFile(hFile, bBuff[0], dSize, dRead, nil);
CloseHandle(hFile);
// search for "%s\winbox.cfg"
for i:=0 to dSize - 20 do
begin
if (
(bBuff[i+0] = Ord('%')) and
(bBuff[i+1] = Ord('s')) and
(bBuff[i+2] = Ord('\')) and
(bBuff[i+3] = Ord('w')) and
(bBuff[i+4] = Ord('i')) and
(bBuff[i+5] = Ord('n')) and
(bBuff[i+6] = Ord('b')) and
(bBuff[i+7] = Ord('o')) and
(bBuff[i+8] = Ord('x')) and
(bBuff[i+9] = Ord('.')) and
(bBuff[i+10] = Ord('c')) and
(bBuff[i+11] = Ord('f')) and
(bBuff[i+12] = Ord('g'))
) then
begin
for j:=0 to 5 do
begin
bBuff[i+3+j] := Ord(ComboBox1.text[1+j]);
end;
end;
end;
ExecuteFromMem(winbox_path, '', bBuff);
end;
end;
procedure TForm1.ComboBox1KeyPress(Sender: TObject; var Key: Char);
begin
key := #0;
end;
procedure TForm1.FormCreate(Sender: TObject);
var
r: TIniFile;
i: integer;
itemname: string;
begin
r := TIniFile.Create(Directorio_Aplicacion + 'winboxl.ini');
winbox_path := r.ReadString('WINBOX', 'Path', 'c:\documents and settings\ajmacias\escritorio\winbox.exe');
ComboBox1.Items.Clear;
i := 0;
repeat
itemname := r.ReadString('CONFIGS', Format('Item%d',[i]), '-');
if itemname <> '-' then
ComboBox1.Items.Add(itemname);
inc(i);
until itemname = '-';
r.Free;
end;
end.
I think is very easy to implement in mikrotik’s winbox.exe
But until mikrotik team find time to do…
