WinBox Loader import (automatically generated) addresses
I use the WinBox Loader application to configure Routerboards running the Mikrotik RouterOS system. I have many boards and manually typing their addresses, logins and names in to the Winbox Loader application would be an unnecessary and hopefully avoidable pain. I would like to generate a suitable import addresses list for the WinBox loader application, but the structure of the “wbx” files (or winbox.cfg) is a bit hard to follow.
Does WinBox Loader support any other import formats besides the default “wbx” format? Or could anyone be so kind to specify the format of the wbx input files?
http://ayufan.eu/mikrotik/winbox-cfg
Greetings ayufan,
Thank you very much for your reply! Being a PHP programmer myself, C# code seems a little unfarmiliar. Would it be too much to ask you to translate this piece of code to PHP? My main objective is to query a SQL database for the Mikrotik routers and then make a import (or winbox.cfg) file for the WinBox Loader application. A bit more advanced PHP programming isn’t a problem for me, but binary data manipulating and C (C#, etc) is a little gray area for me.
Thank you in advance!
