Winbox log in error
Hi Guys, have anyone run into this problem on MT2.9cr5. I am able to log into my MT box by winbox for the first time I try. When I close my winbox and try to log into it again for a second time, I receive a message could not connect to server. After rebooting my laptop, I am able to log into the winbox for the first time again.
It all boils down to I have to reboot my laptop to be able to log into winbox again.
THX
Ben
try removing winbox.exe and removing all the files associated with it
%userprofile%\Application Data\Mikrotik (delete this entire directory)
then redownload winbox.exe from the router and try try again..
thank you partner I will try that
I tried it and it works thanks again
