I usually login through winbox, but suddenly “authentication failed”.
Username and password saved in winbox, so I suppose an hack.
I login through webfig (same user) and I can logon.
Under “resources” I can read “bad blocks” = 0.1%.
Could be this?
Should I change RB before it will crash completely?
Thanks.
According to the manufacturer of NAND chips, up to 5 blocks can be bad when NAND is manufactured, and up to 80 bad blocks could develop during operation, but it will not disturb the operation of your router, because complex workaround mechanisms are in place, that will copy the data to another block and attempt to fix the bad block.
My guess is that your Winbox version is too recent to authenticate on 3.19. As the colleagues said, upgrading your ROS should be the first step, but just to login you should be fine with an older version of Winbox.
