Winbox Login Time-Out?
Does anyone know if there is a way to create a login-timeout for winbox? Some of us forget to close out their winbox’s after work and for some reason boosts the CPU almost to 100% when logged in. Our simple queues are at around 100-200.
Thanks for any advice.
it would be nice to have possibility to force log-out of the active user…
it sounds good!! :smiley: :bulb:
at the moment no sessions (telnet, winbox, ssh, webfig) are timing out. It has to be done manually by user. If you see weird behaviour when session stays open for long time, please create supout.rif file when you see that happening and send it to support@mikrotik.com.
Well when you have over 100 simple queues, and have 3 or so users logged in over the weekend, it rockets the CPU to 100% even with the 433AH boards. You can kick users of of PPP, but not logged in users. The 100% CPU slows down the routerboard too, only way to kick the users left logged in, is to reboot.
Yeahh, dreeeams… But there is nothing impossible!
