winbox login
so i constantly get this message and cant figure out hoe to make it go away! please help!
login failure for user admin from 127.0.0.1 via winbox
dude server enabled on this device?
looks like a wrong credentials in dude for this device
It’s the loop back address and dosent sure up on a map… Where do I change the credentials?
We can find required device in the Dude: Devices → Addresses
Then update it directly from there: Right click → Device Settings → General → User Name/Password
Have the same annoying problem even i disabled Dude, however, i checked all dude monitored device account ID/PWD, they are all correct.
It specifically said the error comes from winbox.
Login failure for user XXXXX from IP:Y.Y.Y.Y via winbox.
Y.Y.Y.Y is everytime 127.0.0.1???
