Winbox mac version
really there is not a Winbox version for OSX yet? …incredible.
https://github.com/nrlquaker/winbox-mac
@surfparadise,
if there is no Linux version, why should there be for that ___?
@timchenko
it’s not winbox,
it’s just another way to install “wine” under iOSht and still run the winbox.exe Windows version.
Maybe because OSX holds a 15.33% of global desktop market share in January 2022?
If 25% of minors in the US use drugs, it does not mean that all populations is on drugs.
https://ilbolive.unipd.it/it/news/grande-epidemia-stati-uniti-oppioidi-farmaci
The sales statistics do not take into account the decommissioned devices.
Basically, those who have an Apple device tend to change the device unnecessarily,
both because if it is not in the latest fashion, it does not work,
and because at each update they purposely limit something…
Hi. I used to run the WinBox with Crossover on my MacBook M1. Runs fine for my RouterBoard 750. WinBox v3.x also runs well, however I have not tested on a real hardware due to that I don’t own any other MT. Hope this helps.
something strange…
It si not that simple, percentage in this case is unusable, because almost nobody from this field use windows as main os.
If you using winbox, you probably managing more than couple of mikrotik devices. Otherwise it can be done via web.
And if you managing large amount of mikrotik devices, you are probably from it/network/system admin field. And you probably do not using windows.
Because you need ethereal/tshark/good terminal/nmap/good mtr and more and more utilities. You need stable device with robust networking. Which is not windows. Let's be honest.
Not even mikrotik team using windows, just look at Normis.
