[Winbox] Menu items dissapeared after upgrade to ROS 7.5
Hi Community.
I upgraded my Miktorik HAP ac^2 to RouterOS 7.5 today.
After the upgrade I noticed that several menu items are missing when using Winbox; e.g. “Quick Set”, “File List”, “Queues”, “Capsman”.
However the corresponding commands are available from the terminal / cli.
Any idea what’s going wrong here?
Thanks in advance
Moltivan
delete default.json under /skin/
you create a personalized webfig “theme” and on 7.x is applied also on winbox
Oh my gosh - easy as that…
Thanks for the fast reply :slight_smile:
