winbox menu system
Hi
I’m having problems with the winbox utility in that if I run routeros on an intel or amd pc and you click on system and the submenu appear you can’t see the bottom menu items like I can only see to ntp client. If I try tools the same thing happens. Have you guys perhaps have a solution
I have never seen anything like that. Make sure you are using both the newest RouterOS 3.6 and the newest winbox that you donwload from the router itself.
Ajust your screen resolution to at least 1024X768.
I am sure that sorted the problem :laughing:
Steven
Yes
I’m using Routeros 3.6 and the resolution is 1024x768 if i adjust it to 1280x1024 I can see everything but then I have to use the magnifying glass .
Large fonts at 1024X768 will also “chop”…
The munues dont scroll…
Craig
Yes it would help if the menu could scroll
