Winbox not connecting to router.
My hAP AC is on router os 7.1.1. Since upgrading to router os I am having an issue with winbox failing to connect to the router. Never tested whether it occurs over ether or not. Only occurred to devices connected through the wifi. At first, the device lost the internet. After that, the device failed to connect to the router. My router has neighborhood discovery enabled. But, winbox couldn’t find it, neither it can connect. But, among all the devices conencted over wifi (three in testing), only one can connect. I had to reboot the router to get the internet back. The device can connect is random. The only common thing is when this happens the device lost internet, but wifi signal is still there.
Does anyone encounter this issue?
Works fine for all my 7.1.1 devices,
Suggest you configure access OFF the bridge :wink:
Also have you tried by both mac and IP:port
I always use iP to log into. But, router kinda kicks the device out. I will let you know when the next occurrence occurs.
Are you referring dedicating port for router access that you mentioned on your guides?
Though, found this error in mikrotik ios app " failed to establish secure connection"
That happens to me if I try to use mac address aka not able to use discovery on IOS app no matter what.
I can access via wireless if I use the IP address and port.
For it happens with IP address in ios. Not, sure about the mac address, never tried. Will report back. The weirdest part is that device’s loss of internet. To my understanding it can happen for various reasons ( low signal strength, fail to establish secure connection). But, no internet on the device is kinda weird. I will report back next time it happens.
I would like to see your settings to see if you have something amiss for for the OFF Bridge access…
Here is my settings:
# jan/17/2022 01:22:55 by RouterOS 7.1.1
# software id = BM4W-X3GK
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number =
add admin-mac=xxxxxxxxx auto-mac=no comment=defconf name=bridge
set [ find default-name=ether3 ] advertise=\
    100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country=no_country_set disabled=no distance=indoors \
    frequency=auto frequency-mode=manual-txpower installation=indoor mode=\
    ap-bridge ssid=bad station-roaming=enabled wireless-protocol=802.11 \
    wps-mode=disabled
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac \
    channel-width=20/40/80mhz-XXXX country=no_country_set disabled=no \
    frequency=5765 frequency-mode=manual-txpower installation=outdoor mode=\
    wps-mode=disabled
/interface wireguard
add listen-port=13231 mtu=1420 name=Home
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
    xxxxxxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    group-key-update=1h mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=pinet ranges=192.168.188.20-192.168.188.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=pinet interface=ether5 name=pinetDHCP
/routing bgp template
set default as=65530 disabled=no name=default output.network=bgp-networks
/routing ospf instance
add name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing table
add fib name=to_ISP1
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
/ip settings
set max-neighbor-entries=8192 rp-filter=loose
/ipv6 settings
add interface=ether5 list=LAN
add interface=Home list=LAN
/interface wireguard peers
add allowed-address=192.168.40.2/32 interface=Home public-key=\
add allowed-address=192.168.40.3/32 comment="" interface=Home \
    public-key=""
    192.168.88.0
add address=192.168.188.1/24 comment=pinet interface=ether5 network=\
    192.168.188.0
add address=192.168.40.1/24 comment=wireguard interface=Home network=\
    192.168.40.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.188.21 client-id=xxxxxx mac-address=\
    xxxxxxxxxx server=pinetDHCP
add address=192.168.88.0/24 comment=defconf dns-server=192.168.188.25 \
    gateway=192.168.88.1
add address=192.168.188.0/24 comment=pinet gateway=192.168.188.1 netmask=24
set allow-remote-requests=yes cache-max-ttl=2d query-server-timeout=100ms \
    query-total-timeout=5s servers=1.1.1.2,1.0.0.2 use-doh-server=\
    https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add address=104.16.248.249 name=cloudflare-dns.com
add address=104.16.249.249 name=cloudflare-dns.com
/ip firewall address-list
add address=192.168.88.2-192.168.88.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    not_in_internet
add address=192.168.188.20-192.168.188.254 list=allowed_to_router
add address=192.168.40.2-192.168.40.12 list=allowed_to_router
add action=accept chain=input comment="defconf: accept established,related" \
    invalid
add action=accept chain=input comment="Allow Wireguard" dst-port=13231 \
    protocol=udp
add action=accept chain=input comment="Allow ADMIN to Router" \
    in-interface-list=LAN src-address-list=allowed_to_router
add action=accept chain=input in-interface-list=LAN port=53 protocol=tcp
add action=accept chain=input in-interface-list=LAN port=53 protocol=udp
add action=drop chain=input
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=invalid
add action=accept chain=forward comment=" Allow Port Forwarding - DSTNAT" \
    connection-nat-state=dstnat
add action=accept chain=forward comment="ENABLE LAN to WAN" \
    in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="ENABLE LAN to LAN" \
    in-interface-list=LAN out-interface-list=LAN
add action=drop chain=forward comment="Drop All Else"
/ip firewall mangle
add action=log chain=prerouting connection-state="" disabled=yes \
    in-interface=Home log-prefix=WGnew
add action=dst-nat chain=dstnat comment=pihole_bypass disabled=yes \
    dst-address=192.168.188.25 dst-port=53 protocol=udp to-addresses=\
    192.168.88.1
    dst-address=192.168.188.25 dst-port=53 protocol=tcp to-addresses=\
    192.168.88.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=xxxx
set api disabled=yes
set winbox address=192.168.88.0/24,192.168.40.0/24
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote strong-crypto=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=pppoe-out1 type=external
add interface=ether5 type=internal
/system clock
set time-zone-name=Asia/Dhaka
/system logging
add disabled=yes topics=wireless,debug
add disabled=yes topics=dns
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
/system scheduler
add interval=2d name=reboot on-event="system reboot" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=jun/07/2020 start-time=05:05:00
add interval=45s name=bypass on-event=":local piholeDown [/ip firewall nat pri\
    nt count-only where comment~\"pihole_bypass\" && disabled]\r\
    \n:local piholeDNS \"192.168.188.25\"\r\
    \n:local testDomain \"www.google.com\"\r\
    \n\r\
    \n:if (\$piholeDown > 0 ) do={\r\
    \n    :do {\r\
    \n        :resolve \$testDomain server \$piholeDNS\r\
    \n    } on-error={\r\
    \n        /ip firewall nat enable [find comment=pihole_bypass];\r\
    \n    }\r\
    \n} else={\r\
    \n    :do {\r\
    \n        /ip firewall nat disable [find comment=pihole_bypass];\r\
    \n    } on-error={}\r\
    \n}" policy=\
    start-date=may/21/2021 start-time=03:39:00
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
When the issue occurs I am not over vpn.
(1) Why is UPNP enabled.
and more specifically why is the OFF Bridge access listed here…
Should be removed
/ip upnp interfaces
(2) src-address-list=allowed…
as long as your wired connection on ether5 has an IP of 20 or greater (has to match the pool) that part is OK.
(3) Where it falls apart is here.
set winbox address=192.168.88.0/24,192.168.40.0/24 MISSING 192.168.188.0/24
  1. FINALLY when you talk about IOS app not being able to reach the device.
    YOU HAVE NO WLAN SETUP FOR THIS ???
Create WLAN3 (virtual wlan off 2.4 ghz wlan as master interface)
  • ip address=192.168.190.1/24 network=192.168.190.0 interface=wlan3
    etc..
  • Not on bridge.
    add WLAN3 as a LAN member
    Add to source-address-list=allowed 192.168.190.0/24
    Add to winbox settings 192.168.190.0/24
  1. Didn’t configure ether5 as an off-bridge connection. Its dedicated for rpi. Which has some containers which need UPnP.
  2. Devices on the ether5 don’t need to access the router administration. 192.168.188.0/24 I left that intentionally.
  3. No wlan for ios app, The issue only occurred after upgrading to ros 7
Okay but now you have a path forward using WLAN to gain access off the bridge…try it…
Yes, I will definitely. I like the idea of having a separate WLAN outside of the bridge after the recent events blocking myself out of the router in the cold. And finally a use case scenario for an SSID name that I thought of, but couldn’t figure out a use case. :smiley:
Here is the issue so far what I could manage. The router is connected to the device, no logs about the device being disconnected from the router. But, no internet on the device. I had to disable/enable the wifi on the device to get it back online. I tried to connect using mac address but didn’t work.
Sorry I have no idea what I am looking at??
Is that you on a wifi laptop trying to gain access to the router via the Off the bridge wlan ??
I do it via my Iphone but wifi laptop works for me…
IF that is the case, I need to see
a. the config of the MT device
b. the Ipv4 config of the laptop
Didn’t get the chance to create the off bridge wlan, it was the regular wlan that I use to access the router. I was trying to saw you the scenario where device is connected to router , but router denying access to internet.
I will try to create the off-brdige wlan and see if the problem persist. Will report back soon .
Not relevant the existing wlan is ON the bridge LOL. Yes try with third virtual WLAN off the bridge.
Here is the config export:
# jan/21/2022 23:02:24 by RouterOS 7.1.1
# serial number =
add admin-mac=xxxxxxx auto-mac=no comment=defconf name=bridge
/interface wireless
    wps-mode=disabled
    wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=xxxxxxxxxxxx \
    master-interface=wlan1 multicast-buffering=disabled name=wlan3 ssid=test \
    wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
    xxxxxxxx
add name=Manage
/interface lte apn
add name=default-v2
/routing ospf area
/routing table
set discover-interface-list=Manage
/ip settings
/ipv6 settings
add interface=wlan3 list=Manage
add allowed-address=192.168.40.3/32 comment="iPhone 7" interface=Home \
    public-key=""
    192.168.88.0
    192.168.188.0
    192.168.40.0
add address=192.168.50.1/24 interface=wlan3 network=192.168.50.0
/ip cloud
/ip dhcp-client
/ip dns static
    not_in_internet
add address=192.168.50.0/24 list=allowed_to_router
    invalid
    protocol=udp
/ip firewall mangle
add action=add-dst-to-address-list address-list=YouTube address-list-timeout=\
    none-dynamic chain=prerouting comment=YouTube content=youtube.com
    none-dynamic chain=prerouting comment=YouTube-googlevideo.com content=\
    googlevideo.com
add action=add-dst-to-address-list address-list=Netflix address-list-timeout=\
    none-static chain=prerouting comment=Netflix content=netflix.com
add action=add-dst-to-address-list address-list=Facebook \
    address-list-timeout=none-static chain=prerouting comment=Facebook \
    content=facebook.com
    address-list-timeout=none-static chain=prerouting content=fbcdn.net
    address-list-timeout=none-static chain=prerouting content=fbsbx.com
add action=add-dst-to-address-list address-list=Instagram \
    address-list-timeout=none-static chain=prerouting comment=Instagram \
    content=instagram.com
    address-list-timeout=none-static chain=prerouting content=\
    connect.facebook.net
    cdninstagram.com
add action=add-dst-to-address-list address-list=twitter address-list-timeout=\
    none-static chain=prerouting comment=twitter content=twitter.com
add action=add-dst-to-address-list address-list=Reddit address-list-timeout=\
    none-static chain=prerouting comment=Reddit content=reddit.com
add action=add-dst-to-address-list address-list=tumblr address-list-timeout=\
    none-static chain=prerouting comment=tumblr content=tumblr.com
add action=add-dst-to-address-list address-list=TikTok address-list-timeout=\
    none-static chain=prerouting comment=TikTok content=tiktok
    none-static chain=prerouting content=musical.ly
add action=add-dst-to-address-list address-list=rarbg address-list-timeout=\
    none-static chain=prerouting comment=rarbg content=rarbg.to
    none-static chain=prerouting content=dyncdn.me
    none-static chain=prerouting content=rarbgtor.org
add action=add-dst-to-address-list address-list=1337x address-list-timeout=\
    none-static chain=prerouting comment=1337x content=1337x.to
    none-static chain=prerouting content=dyncdn.cc
add action=add-dst-to-address-list address-list=thepiratebay \
    address-list-timeout=none-static chain=prerouting comment=thepiratebay \
    content=thepiratebay.org
    address-list-timeout=none-static chain=prerouting content=torrindex.net
    address-list-timeout=none-static chain=prerouting content=cdn.izooto.com
add action=add-dst-to-address-list address-list=pubg address-list-timeout=\
    none-static chain=prerouting comment=PUBG content=ap-south-1 \
    dst-address-list=""
    none-static chain=prerouting content=cdn.pubg.com dst-address-list=""
add action=mark-packet chain=forward new-packet-mark=YouTube passthrough=no \
    src-address-list=YouTube
add action=mark-packet chain=forward new-packet-mark=Netflix passthrough=no \
    src-address-list=Netflix
add action=mark-packet chain=forward new-packet-mark=Facebook passthrough=no \
    src-address-list=Facebook
add action=mark-packet chain=forward new-packet-mark=Instagram passthrough=no \
    src-address-list=Instagram
add action=mark-packet chain=forward new-packet-mark=twitter passthrough=no \
    src-address-list=twitter
add action=mark-packet chain=forward new-packet-mark=Reddit passthrough=no \
    src-address-list=Reddit
add action=mark-packet chain=forward new-packet-mark=tumblr passthrough=no \
    src-address-list=tumblr
add action=mark-packet chain=forward new-packet-mark=TikTok passthrough=no \
    src-address-list=TikTok
add action=mark-packet chain=forward new-packet-mark=rarbg passthrough=no \
    src-address-list=rarbg
add action=mark-packet chain=forward new-packet-mark=1337x passthrough=no \
    src-address-list=1337x
add action=mark-packet chain=forward new-packet-mark=thepiratebay \
    passthrough=no src-address-list=thepiratebay
add action=mark-packet chain=forward new-packet-mark=pubg passthrough=no \
    src-address-list=pubg
    192.168.88.1
    192.168.88.1
/ip service
set ssh port=2133
/ip ssh
/ip upnp
set enabled=yes
/ip upnp interfaces
/system clock
/system logging
add topics=wireless,debug
/system ntp client
set enabled=yes
/system scheduler
    \n\r\
    \n    :do {\r\
    \n    } on-error={\r\
    \n    }\r\
    \n} else={\r\
    \n    :do {\r\
    \n    } on-error={}\r\
    \n}" policy=\
set enabled=no
/tool mac-server
set enabled=no
What I am doing wrong ? Though, both router and phone showing connected, but phone not showing wifi signal icon.
(1) WHY is wlan3 the only interface with Manage…???
(2) Problem: Figure it out and it has to do with (1) being used not fully!!
add action=accept chain=input comment=“Allow ADMIN to Router”
add interface=wlan3 list=Manage ( Good but ?? which interface does the admin use?? ether5? LAN? )
Remember Manage is also what we use for
IP neighbours discovery = Manage
set allowed-interface-list= Manage
So recommend either adding ether5 or LAN whichever one is correct to Manage!!
So that the admin can connect to winbox from all Manage locations!!
The alternative is to add wlan3 to LAN interface and forget about interface Manage altogether.
wlan3 is the only interface because I wanted to make a virtual hidden interface to the router as a fail safe. So, that I can access the router, regardless of firewall rules.
I liked the line :smiley: . But, the question that still remains, if I add wlan3 to the LAN interface, how do I gain access if locked myself out of the router? For my home network, LAN is trusted.
Sorry, for the delay. Getting old means too little time for my router :laughing:
You are overthinking it and adding noise I never stated. There is nothing HIDDEN about it.
Only you will have the SSID password to access the vWLAN plus, you are the only one with the correct IP address and port for winbox when using winbox, PLUS you are the only authorized user LOL.
(1) On the managed interface list, you should have the subnet you are on ALL the time as admin to be able to reach the router, lets say its Home
Then your interface list members would include
add interface=Home list=Manage
If you as admin are on ether5 all the time and access winbox from there normally then your list would have
add interface=ether5 list=Manage
(2) You need to add the specific IP addresses here if relevant. MISSING
set winbox address=192.168.88.0/24,192.168.40.0/24, 192.168.50.0/24
(3) This needs to be set to Managed
(4) YOur source list allowed to router is not needed. That is what you have the interface list “Managed” for!!!
From
in-interface-list=LAN src-address-list=allowed_to_routershould be:
add action=accept chain=input comment=“Allow ADMIN to Router” in-interface-list=Manage
[ src-address-list=IP , SHOULD BE FOR SPECIFIC IPs if necessary, if you want to narrow it down to Admin PC, Laptop, IPAD, Smartphone, Laptop IP for accessing wlan3 ]
