Winbox notepad field for unstructured text/notes?
Hi all!
As there is the possibility to add comments on nearly every item in ROS I just wonder if there is a possibility or field that serves as a notepad for general text information like inventory number, customer info, some unstructured text of any purpose. Somewhat like “/system notepad”.
At the moment i just use a dummy script and use the code field for that information - somehow suboptimal i know.
I know there is /system note but that serves primarily as a hello message on terminal-logins (if enabled) and is only editable via terminal and not nicely in a winbox window. Also suboptimal.
Yes you might argue to place some textfile in the file section but editing nicely is not possible (drag’n drop the file onto desktop, edit it and drag it back… hm).
Any suggestions or might this be a feature request candidate?
Regards!
