Winbox Option Question
Hello guys,
Just a question next to some options of winbox there is a small box that when you click on it it puts a ! character infront of the information you add.
The ! character is it a logic NOT operator ???
i.e. if I give an ip range 192.168.1.0/24 and click the box it will select the rest of the range and NOT the 192.168.1.0/24 address space…
Regards,
Sotiris
Yes you are right, ! is logic NO.
sergejs, I tried this test;
chain=forward action=drop src-address-list=!hilton layer7-protocol=MSN
list hilton= ip address of my pc.
If I enable this rule without the src-address-list, MSN is blocked (as expected)
If I then specify that the src-address-list should be everyone NOT me, I still cannot connect.
What could I be doing wrong?
Maybe try this rule:
chain=forward action=drop src-address-list=!hilton dst-address-list=!hilton layer7-protocol=MSN
mrz, you are the man!
thanks mate.
Do I need both the src and dst address lists because of the tcp handshake?
Yes you can say so. Packets are flowing in both directions and all of them are matched by l7 filter rule.
thanks mrz.
Thanks man. that is f…king amazing.
Sotiris
