I am trying to access the mtik (mAP-001) using winbox at its wireguard IP of 192.168.32.5 through a Cloud Hosted Router (CHR) with a wireguard IP of 192.168.32.1 via its (CHR) WAN IP.
It would be nice if I could just connect to CHR RoMon and see MAP-001 and connect to it, but I’m unsure how to make this happen, could someone please help? Thanks for your kindness. ![]()
CHR config:
set [ find default-name=ether1 ] disable-running-check=no
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
set discover-interface-list=all
/interface wireguard peers
add allowed-address=192.168.22.0/24 interface=wireguard1 name=peer2
public-key="xxxx"
add allowed-address=192.168.32.0/24 disabled=yes interface=wireguard1 name=
MAP-001 public-key="xxxx"
laptop public-key="xxxx”
add allowed-address=192.168.32.0/24 interface=wireguard1 name=mAP-001
public-key="xxx"
add address=192.168.32.1/24 interface=wireguard1 network=192.168.32.0
add address=192.168.22.1/24 interface=wireguard1 network=192.168.22.0
/ip dhcp-client
add interface=ether1
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="remote access" dst-port=8291 protocol=
tcp
add action=drop chain=input comment="defconf: drop all not coming from LAN"
disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes
/ip service
set ftp disabled=yes
set ssh disabled=yes
set telnet disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=CHR-001
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool bandwidth-server
set authenticate=no enabled=no
mAP-001 config:
add admin-mac=08:55:31:xx:xx:xx auto-mac=no comment=defconf name=bridge
port-cost-mode=short
add name=bridge-WAN
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-ATA
add listen-port=13231 mtu=1420 name=wg1
/interface lte apn
add authentication-types=wpa2-psk mode=dynamic-keys name=xxxx
supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX
country="united states3" disabled=no frequency=auto mode=ap-bridge name=
wlan1-WAN security-profile=xxxx ssid=xxxx
wps-mode=disabled
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge-WAN comment=defconf ingress-filtering=no interface=
ether2-ATA internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=pwr-line1
add bridge=bridge-WAN interface=ether1-WAN
add bridge=bridge-WAN interface=wlan1-WAN
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add comment=defconf interface=wlan1-WAN list=WAN
add comment=defconf interface=wg1 list=LAN
add interface=ether1-WAN list=WAN
/interface ovpn-server server
add auth=sha1,md5 mac-address=FE:63:00:4C:0E:00 name=ovpn-server1
add allowed-address=192.168.32.1/32 endpoint-address=CHR-001
endpoint-port=13231 interface=wg1 name=CHR-001 public-key=
"xxxx"
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.32.5/24 interface=wg1 network=192.168.32.0
/ip dhcp-clientInterface not active
DHCP client can not run on slave or passthrough interface!
add default-route-tables=main interface=bridge-WAN
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
invalid
add action=drop chain=input dst-port=22 protocol=tcp src-address=
!192.168.32.1
tcp
/ip hotspot profile
/ip ipsec profile
/ip service
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system identity
set name=mAP-001
/system scheduler
add name=schedule1 on-event="ping 192.168.32.1" policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-time=startup
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
