Is it possible to sniff winbox password with wireshark?
Only if you’re not using secure mode.
I am not using it but cant see password anyway. Only user name
Isn’t that a good thing?
Yes, but not in my situation
Let me guess, you have the password saved in the GUI and you forgot it?
If you are trying to find your saved password, goto Start → Run..
“%APPDATA%”
Mikrotik → Winbox
winbox.cfg
