can i change the default winbox port in services
i guess my question is can i change winbox port to “custom”
as i figured i would also need to change the port in the winbox application
“though i could not find the place to change in winbox app itself”
Sob
2
Yes, you can change the port and you can connect to it, syntax is like almost everywhere else: [:], so for example 192.168.1.1:12345.
i see
so i would just specify port in the “connect to:” box
after the ip
in the winbox app
thanks sob your a legend
the answer was staring me in the face thanks: )
