Where can I change the winbox Portnumber in the Dude ?
netstat -an shows the Dude automatically connects to 8291.
I have to change the Portnumber on one device to other than 8291.
If I enter 10.XXX.XXX.XXX:8292 in the Address Field it says invalid Address.
Please add the ability to enter also a Portnumber.
thanks
You will need a copy of winbox.exe on the dude server. Some of the older versions of Winbox did not work with port numbers, but newer versions do, so make sure you have the latest Winbox v2.2.18 (http://www.mikrotik.com/download).
Create a new Tool in the Dude for this, something like this:
It will show up in the Tools menu…
