I’d like to access my switch through my firewall’s DDNS service ie: firewall.ddnsprovider.com :xxxx
Where xxxx is the “port”
I know how to make that possible on the firewall end, but not sure what port Winbox requires? Then it means I can access it anywhere, and it would be easy to control from well, any where
anav
September 25, 2020, 5:19pm
2
Then it would not be a firewall but a security risk. ( a weak professional '-p )
Access to your router via the internet should be done via VPN.
Anything else is not recommended.
Eh. I’d enable / disable the VIP as and when is required. I also would do that but I don’t have a firewall on this side of things
Sob
September 25, 2020, 7:05pm
4
If you didn’t change it (in IP->Services), default for WinBox is tcp port 8291.
