Hey guys. I am new to the mikrotik os and I would like to find a good guide for using winbox to setup my new rb532 as a wireless ap. Yea I searched the formum and yes I also googled.
Thanks for the help.
winbox is easy to navigate.
use the documentation - http://www.mikrotik.com/docs/ros/2.9/
the winbox is only a visual representation of the console commands. you can read the manual and then do the same in winbox. for example if the manual says “ip firewall add src-address=1.1.1.1” then go to winbox, click ip, click firewall click add and enter src-address …
Thanks for the help I’ll give it a try.
