winbox real-time value freeze
hi.. when i log into my router via winbox, the real-time monitor freeze. For example when i click interfaces > EoIP tunnel, under each EoIP, by right the value of the “Tx” and “Rx” column is update real time, but not the value freeze, for example “Tunnel A” value is 128.8kbps for Tx, and 400kbps for Rx.
I have tried log out from the winbox and log in again, but the value still stuck/freeze at 128.8kbps for Tx and 400kbps for Rx.
Although the connection is still working fine, but i want to fix it because sometime we use the real-time monitor to troubleshoot.
Thanks!
has anyone experience this problem before? would be appreciate your kind help..
Thanks! :slight_smile:
You didn’t say which RouterOS you use. did you try RouterOS v5.7?
hi, i using V3.28, due to some reason, i can’t upgrade the routerOS now… would like to know is there anyway to solve it without upgrading it.
Thanks!
your version is several years old. if it has a problem, it was fixed years ago.
