winbox remote access not working
can you see anything in the config which would stop me from using winbox on an outside computer or http and connecting to the router?
dec/18/2017 21:53:52 by RouterOS 6.40.5
software id = KCT3-DJ3C
model = RouterBOARD 750UP r2
serial number = 5BBD0527C6A6
add fast-forward=no name=bridge1
set [ find default-name=ether1 ] name=ether1-WAN-sat-modem
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] name=ether3-Colmar poe-out=off
set [ find default-name=ether4 ] name=ether4-Inside1
set [ find default-name=ether5 ] name=ether5-OtherNet
/ip neighbor discovery
set ether1-WAN-sat-modem discover=no
set [ find default=yes ] supplicant-identity=RTR_KDish
/ip hotspot profile
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=HotSpot ranges=172.16.80.100-172.16.95.250
add name=PPP ranges=172.16.79.10-172.16.79.250
add address-pool=HotSpot authoritative=after-2sec-delay disabled=no
interface=bridge1 name=server1
/system logging action
set 1 disk-file-name=log
add bridge=bridge1 interface=ether2-master-local
add bridge=bridge1 interface=ether3-Colmar
add bridge=bridge1 interface=ether4-Inside1
add address=172.16.80.1/20 interface=bridge1 network=172.16.80.0
add address=172.16.79.1/24 interface=bridge1 network=172.16.79.0
add address=172.16.255.51/29 interface=ether5-OtherNet network=172.16.255.48
/ip dhcp-client
add comment=“default configuration” dhcp-options=hostname,clientid disabled=
no interface=ether1-WAN-sat-modem
add address=172.16.80.0/20 gateway=172.16.80.1
add address=192.168.88.0/24 comment=“default configuration” gateway=
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=10.0.0.0/8 list=allowed_to_router
add address=172.16.0.0/16 list=allowed_to_router
add address=103.36.147.0/24 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment=“6to4 relay Anycast [RFC 3068]” list=
not_in_internet
add action=drop chain=input log-prefix=winbox___ src-address=54.227.238.230
add action=accept chain=input disabled=yes src-address=202.80.0.0/16
add action=accept chain=input disabled=yes log-prefix=WanTok__ src-address=
103.36.0.0/16
add action=accept chain=input disabled=yes dst-port=8291 log=yes log-prefix=
GPT_ protocol=tcp src-address=103.36.147.114
add action=accept chain=input disabled=yes dst-port=8291 protocol=tcp
src-address=172.16.0.0/16
winbox___ protocol=tcp
add action=accept chain=input disabled=yes src-address=113.11.0.0/16
add action=accept chain=forward disabled=yes src-address=10.0.0.0/8
add action=accept chain=forward disabled=yes src-address=172.16.0.0/16
add action=accept chain=input disabled=yes src-address=172.16.0.0/16
add action=accept chain=input disabled=yes protocol=udp src-port=53
add action=accept chain=input disabled=yes protocol=tcp src-port=53
add action=accept chain=input disabled=yes dst-port=53 protocol=udp
add action=accept chain=input disabled=yes dst-port=53 protocol=tcp
add action=accept chain=input comment=“default configuration”
add action=accept chain=input src-address-list=allowed_to_router
add action=drop chain=input log=yes log-prefix=drop
add action=drop chain=input disabled=yes in-interface=ether1-WAN-sat-modem
log=yes log-prefix=cleanup
add action=fasttrack-connection chain=forward comment=FastTrack
add action=accept chain=forward comment=“Established, Related”
add action=drop chain=forward comment=“Drop invalid” connection-state=invalid
log=yes log-prefix=invalid
“Drop tries to reach not public addresses from LAN” dst-address-list=
not_in_internet in-interface=bridge1 log=yes log-prefix=!public_from_LAN
out-interface=!bridge1
“Drop incoming packets that are not NATted” connection-nat-state=!dstnat
connection-state=new in-interface=ether1-WAN-sat-modem log=yes
log-prefix=!NAT
“Drop incoming from internet which is not public IP” in-interface=
ether1-WAN-sat-modem log=yes log-prefix=!public src-address-list=
not_in_internet
“Drop packets from LAN that do not have LAN IP” in-interface=bridge1 log=
yes log-prefix=LAN_!LAN src-address=!172.16.80.0/20
add action=masquerade chain=srcnat comment=“default configuration”
out-interface=ether1-WAN-sat-modem
add distance=1 dst-address=10.0.0.0/8 gateway=172.16.255.53
add distance=1 dst-address=172.16.0.0/20 gateway=172.16.255.53
/system clock
set time-zone-name=Australia/Sydney
/system identity
set name=RTR_KDish
As i can see your rules for winbox are disabled.
with all rules enabled it still doesn’t work. i can see icmp traffic but can’t see winbox 8291 or http 80 traffic hitting the router from outside, and there is no firewall between this mikrotik router and the internet.
