once i open winbox for my router i m facing tooo much window opend,
even if i clear the winbox cache, even using another computer,
how can i resolve this problem
my winbox crash when i try to open this router
but other routers work great with the same winbox
i m using RB/112
quckly answer will help very much
My friend i have a same problem, the first thing i do was delete any entries of winbox from windows, second thing check the cables UTP, sometimes the cable is damage then connection with RB crash, and the tree thing i do is download winbox from the RB. and try and try until connect. i think that this problem can fix with early versions.
i had this same problem that made it difficult connecting to an RB532 for over a week. Winbox keeps crashing, no matter from what PC i connect from. I notice this with so many windows opened especially with the ‘bridge’ window.
I finally got winbox working by quickly pressing the ‘esc’ key on the keyboard several time to close the windows before it could have the chance to crash again. your fingers must be fast to get this right…
Mikrotik should create a means to reset opened windows by telnet.
Sonny
exactly when using brige and vlan
i access throw telnet and just delet and disable some entries then every think going OK
My winbox blows up after reinitiating terminal connections as far as i can gather on the packet dumps. It does it from all computers, with or without cleaning cache.
I’ve never liked this features implementation.
The idea to store “last used” preferences is perfectly fine but the “… and let’s store them on the router! …” idea was not! A -ROUTER-! What’s next?!
could you provide us winbox access to such router so we could reproduce that using winbox from here to debug it? send that info to support@mikrotik.com
I have sent supout’s and description of problem.
I got frustrated/bored so i reprogrammed it after resetting.
A packet sniff showed that it kept logging into terminal (telnet?) and then blew up. The problem showed up after the license Yes/No question was introduced. I think it was v2.9.21 or v2.9.22 before i attempted upgrade to v2.9.23 to see if that helped – it didnt.
