I get that a lot… for some reason winbox cannot connect anymore… and the connect to romon button is lost…
to resolve I go to %appdata% and delete the mikrotik folder that stores the sessions and then I can work again…
any non temporary solutions? or what is causing it to avoid ?
I connect a lot to romon clients
I do have the same issue. After using romon feature I am unable to login to login to any router. It shows error WINBOX: ROMON AGENT NOT FOUND . ADD IT TO MANAGED LIST . . in red color error.
Please help
The romon agent, the router which will provide the access to romon network, and to which Winbox needs to connect first before accessing any romon clients, needs to be stored in the managed list.
Is that the case?
In order to restore connection need to remove file " settings.cfg.viw " from path “%AppData%Roaming\Mikrotik\Winbox”.
Regard,
Rustam.
I got the same problem after using Romon in WinBox 3.27.
Strange that this can not be fixed without deleting a file?
Correct path for file (for me was):
%AppData%\Mikrotik\Winbox
File:
settings.cfg.viw
And years later still not fixed - at least they could show a logout button. Whow.
