Winbox Session Freezing and BGP/iBGP uptime restart
Hi Sir/s,
Just would like to ask if any of you has already experienced your Winbox sessions freezing randomly?
The moment this happens, it usually takes me 5-10mins of NOT being able to connect to the CCR 1036
via Winbox, I can only re-connect after 5-10mins.
I have eBGP and iBGP running on the said router, I’ve also noticed that every time eBGP peering would
go down, iBGP goes down as well. I’ve noticed this by taking note of the “uptime” timer for both eBGP
and iBGP. Is this a normal behavior? I have another CCR 1036 which does not not exhibit the same
unusual behavior.
Looking forward to hearing your responses.
Thanks.
Vincent
