Winbox Shortcuts Keys
I know it was dangerous a key to disable interfaces. But is there a chance to add to winbox a shortcut do edit comments, like F2 key?
It would be very convenient to have some keyboard shortcuts to these non critical operations.
:smiley:
control+M
to edit comments.
i wish there was a list of winbox GUI keyboard shortcuts (not terminal/cli). this info is hidden for some reason.
tks
http://forum.mikrotik.com/t/winbox-gui-hotkeys-and-keyboard-shortcuts/129755/1
thanks, but those are winbox Terminal / CLI commands i was referring to in my post, they are not commands for using winbox itself. (ie what is winbox keyboard shortcut to disable or enable a rule - a list like that is what myself and many others on the forums are looking for).
tks
I only find F6 useful… :laughing:
These work for me in current WinBox (as of 2021-09-16)
1. WinBox-specific shortcuts
Ctrl + A = select all
Ctrl + D or Num- = disable
Ctrl + E or Num+ = enable
Ctrl + F = find
Ctrl + G = find next
Ctrl + M = edit comment
Ctrl + + = zoom in – the entire WinBox view
Ctrl + - = zoom out – the entire WinBox view
Tab = next control (+Shift = previous control) • in table view it also focuses icons
• arrow keys do the same if not occupied by another function, e.g. by moving cursor (example: in tables, Up/Down moves, but Left/Right is still selecting controls)
Ctrl + Tab = next tab, if there are tabs (+Shift = previous tab), else next window
• this has a bug and sometimes changes window instead of tab
Space = activate focused control (e.g. button) – if it is not a text box
Ins = add record (into table) • add value (into multi-value field)
Del = delete current record (from table) • delete current value (from multi-value field)
Esc = close window
F2 = edit comment
F3 = find, then find next (Ctrl + F and Ctrl + G combined)
F4 = close window
F6 = previous window (+Shift = next window)
F10 = menu
2. Natural Windows shortcuts
Alt = menu
Alt + S, Down = open Session menu (because of initial letter S which is first of two conflicting accelerator keys)
Alt + S, S, Down = open Settings menu (because of initial letter S which is second of two conflicting accelerator keys)
Alt + D = open Dashboard menu (Down arrow is not needed because initial letter D has no conflicts with other menu items)
• after this, if a submenu is open, press initial letter of an item to select it • if there are more items with key conflict (starting with same letter), press the letter as many times and needed and confirm by Enter
Alt + Space = open Windows system menu (Maximize, Minimize, etc…)
Alt + F4 = close WinBox
Shift + Up/Down = select range of items in table
Ctrl + Space = toggle selection of individual table items
Ctrl + Up/Down = move selection cursor without affecting items selected by Ctrl + Space
Using the AutoHotKey (https://www.autohotkey.com/) you can make the WinBox a bit more practical and safer, see the following code example:
• Stop Del key from causing accidents (it is dangerous in tables) and move its function to Shift + Del.
• Add a Disconnect Session command to Ctrl + Shift + D.
• Add a Show/Hide Passwords toggle to Alt + F8. (This is standardized Windows shortcut to show content of password input field with eye icon.)
#IfWinActive, ahk_class routeros_main ahk_exe winbox.exe
; stop Del key from accidental deletion in tables and move this function to Shift+Del
Del::MsgBox % "Del key is blocked – use Shift + Del instead."
+Del::Send {Del}
+^d::	; disconnect session
	Send !s{Down}d
	Return
!F8::	; show/hide passwords
	Send !s{Right}{Down}h
	Return
#IfWinActive
