Did anyone faced this kind of issuee, I’m using Kubuntu as a desktop but I have a problem with Winbox and wine after the winbox is executed it stops responding, this is not happening with other windows applications.
Regsrds.
Faton
Regsrds.
Faton
anyone had this problem, or knows about it.
regards.
faton
I’ve use Kubuntu too (both Gutsy and Feisty), the latest Wine installed. I have not experienced any problems with Winbox there.
Make sure that you have the latest version, try to look at logs to get more details about your problem.
I will just wait for the release of gutsy in these two days, and than install the latest wine and see if this problem will disapear.
Thanks anyway.
Regards
Faton
could it be the firewall still block the port for winbox?
The problem disapeared with gutsy and latest wine.
Regards.
Faton
