winbox timeout from wan port but ping works
Guys,
i added the firewall run so to open port 8291 but no luck
i cant connect to the router with winbox from the wan port
ping to the wan works
firewall rules are stock i just added the winbox one
look the pic below .. line 5 .
https://prnt.sc/uQJN3eIScuM2
routerboard model below
https://prnt.sc/fqGChtOVniYU
Yep, but do you have these (they are default)?
/tool mac-server
/tool mac-server mac-winbox
If the port you are using is not in the LAN interface list the second will prevent winbox access.
You need:
set allowed-interface-list=all
if you want access from both LAN and WAN ports (and AFAIK you don’t need a special rule in firewall for port 8291, while it is vital to disable - as you did - the rule “drop all not coming from LAN”)
it is a SXT R that have an EM06-A LTE RADIO
and so im assuming the WAN is on the LTE side ?
what commands i need to do on the terminal so i can pull the info you need
i dont know on what part to look in winbox
i can reach the box via the public IP
when i ping it
but some how winbox refuse to connect.
it just times out
I lost you, in the title you talked of a WAN port? :confused:
It is entirely possible that you have changes in the configuration that reverse the default logic of Mikrotik (winbox access only allowed from LAN side)
Anyway, if you can somehow connect with winbox from one of the ethernet ports or via WI-FI, follow these instructions:
http://forum.mikrotik.com/t/forum-rules/173010/1
and post your configuration.
@rolo95 - Just some friendly advice: never ever expose your router services, like port 8291, for external access through the internet on the LTE/WAN port. Instead, use a VPN like RouterOS ‘Back to Home’ or similar. Also, avoid using ‘/tool mac-server mac-winbox set allowed-interface-list=ALL’.
yes i can access winbox from the LAN side , with a cable connected to the ETH1 ( that device only have 2 ports )
WAN side i mean, connecting from a remote location, im using my cellphone with the mikrotik app and also tried with a laptop via a hotspot and
even i can ping the mikrotik , the winbox session just timeout and cant connect.
ok i created the dump file but it won’t let me paste in to a notepad, nothing happens
and i already tried paste… CTR-V , arrggg
i wish MT made drag and drop from the files window possible but that do not work either
https://prnt.sc/dg8dr7Gck22o
AHH!!!
i was able to make it to work
i can drag to the desktop
ok so i dragged it
change the extension to TXT ( that is not mentioned in the guide lol )
opened it
select all
CTRL -C
click CODE brackets
CTRL -V
DONE !!
# 2024-05-29 09:26:22 by RouterOS 7.14.3
# software id = A2N8-******
# model = RBSXTR
# serial number = HG1********
add admin-mac=18:FD:******* auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
set [ find default-name=ether1 ] mac-address=18:FD:*******
set [ find default-name=ether2 ] mac-address=18:FD:*******
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=broadband use-network-apn=yes
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=broadband \
    band=4 network-mode=lte sms-read=no
/ip hotspot profile
add name=dhcp ranges=192.168.88.100-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether1 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
set udp-timeout=10s
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add comment=defconf interface=lte1 list=WAN
    192.168.88.0
/ip cloud
set ddns-enabled=yes
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1,8.8.8.8 \
    gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment=WINBOX connection-nat-state=dstnat \
    connection-state=new connection-type="" dst-port=8291 protocol=tcp
    invalid disabled=yes
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=change-ttl chain=postrouting new-ttl=set:64 out-interface=lte1
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ppp secret
add name=vpn
/system clock
set time-zone-autodetect=no time-zone-name=America/Chicago
/system identity
set name=iPhone12
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
/system watchdog
set watch-address=1.1.1.1
/tool mac-server
see the pic below
https://prnt.sc/pp7MmiB6o5bp
It’s a pity they don’t support the MIPS platform for BTH for some weird reason. But there’s always the “regular” WireGuard that BHT also uses. The important thing is that you never expose ROS services directly to the internet.
Btw, you can attach files to your posts using the “Attachments” button, just to the right of “Options” at the bottom of the editor.
EDIT:
  1. immediately remove “add action=accept chain=input comment=WINBOX connection-nat-state=dstnat
    connection-state=new connection-type=“” dst-port=8291 protocol=tcp
  2. Setup some kind of VPN like WireGuard, L2TP and add the VPN interface to the LAN interface-list.
  3. Connect Winbox using VPN.
  4. Solved :wink:
nevermind…
ic
just dipping my toes in to the command line but i use winbox all the time
where are those settings in winbox
and also using the android built in VPN what is the protocol to use in the MT
so i can VPN from the android phone and use the MT android app to connect
I think Wireguard would work great. Start a new thread asking for help with setting up Wireguard (like “How to setup Wireguard for RBSXTR”) using the same text you just described about your need to connect your Android with Wireguard. Include the previous export and mention which Mikrotik model it is and that it’s an LTE device.
10-4
Thanks for you Help !
