Winbox ubuntu 10.04
Is there alternatives to Winbox for ubuntu 10.04?Or another method to open winbox
I used Wine to open winbox.exe but no success
edit:
I get the fallowing error:
An error occurred while loading the archive
-command line output
Archive: /media/Local Disk/winbox.exe
[/media/Local Disk/winbox.exe]
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
note: /media/Local Disk/winbox.exe may be a plain executable, not an archive
zipinfo: cannot find zipfile directory in one of /media/Local Disk/winbox.exe or
/media/Local Disk/winbox.exe.zip, and cannot find /media/Local Disk/winbox.exe.ZIP, period.
what do you mean by “no success”, explain further. it works fine for other people
there are no alternatives .. what problem exactly you have with wine? We are using it on 10.04 without any problems.
Oh I see.
I need to choose open with wine from the right click menu. I thought I just need to souble click in wibox since it has glass of wine on it.
pick “open with other…”, choose wine and check “remember application association”.
Next time you double click on winbox.exe it will be executed.
Guys,
I was able to installed both wine and winbox to my ubuntu 10.04 lts which worked for a while and then stopped working…
I am able to access the winbox by allowing it as .exe to run with wine, it work well as i said but stopped..
What could be the problem or what can i do to fix the problem?
