maybe this is tweakable but I fear not but on a HiDpi screen Winbox is unusable.
I can increase font size under wine which works except for windows with a large number of rows.
see screenshot
see screenshot
Yes, currently Winbox is not optimized for non-standard DPI. You must use the display native resolution without DPI scaling.
Have you tested to installed the windows fonts to wine ??
sudo apt-get install ttf-mscorefonts-installer
or install winetricks and do
sh winetricks corefonts
Hi Patrik,
Thanks for your ideas
I’ve tried that and it doesn’t make any difference.
As Normis said, Winbox doesn’t support non standard dpi. When I use the default resolution, Winbox displays correctly but everything is too small to read on a HiDpi screen.
It doesn’t sound like there will be a fix any time soon either ![]()
