WinBox v.6.36.1 problem with Addresses List
I need to use for one rule Addreess list. In older version there was possibility to write the first and last address from some range. And this address list was OK for a rule. But now, I can’t write whole last address, software shorts it only to last two numbers. But for rule it is not OK. The rule can’t work with this range. I have to bypass in very complicated way. You can see it in added screen
thx for advice
If you want to use address range, enter both complete addresses (“10.1.10.2-10.1.10.30”). It works with both bugfix (6.38.7) and current (6.40) versions. If it by any chance does not work with 6.36.1, then upgrade.
