Hi to all
I am now to mikrotik forum and i need help
i have one RB2011UAS-2Hnd and i have create 4 network one hotspot and everything work perfect
i live default username and blank password (by default)
I connected as much as I did the arrangements and i finish every perfect
today i tray to connect and i saw this error (ERROR: wrong username or password)
this is the the 3rd time i do reset and reinstall my settings (and the 2 others time i have the same problem ERROR: wrong username or password)
the first time I had the version 6.32
sorry for my bad english!!
this is my setting
[admin@MikroTik] > export
jan/11/2016 23:24:20 by RouterOS 6.33.3
software id = TF51-TF8H
set [ find default-name=ether1 ] name=ether1_Service_Network
set [ find default-name=ether2 ] master-port=ether1_Service_Network
set [ find default-name=ether3 ] master-port=ether1_Service_Network
set [ find default-name=ether4 ] master-port=ether1_Service_Network
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] name=ether7-UBNT-WiFi_Front_Ap
set [ find default-name=ether8 ] name=ether8-UBNT-WiFi_Back_Ap
set [ find default-name=ether9 ] disabled=yes name=ether9-VDSL-Home
set [ find default-name=ether10 ] name=ether10-VDSL-Shop
set [ find default-name=sfp1 ] name=sfp1_Switch_192.168.1.1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether9-VDSL-Home max-mru=1480
max-mtu=1480 mrru=1600 name=“Ote Spitiou” password=****** user=
@.gr
add add-default-route=yes disabled=no interface=ether10-VDSL-Shop max-mru=1480
max-mtu=1480 mrru=1600 name=Ote_Magaziou password=***** service-name=
Ote_Magaziou user=@.gr
add authentication-types=wpa-psk eap-methods=“” management-protection=allowed
mode=dynamic-keys name=******** supplicant-identity=“”
wpa-pre-shared-key=*********** wpa2-pre-shared-key=***********
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=greece disabled=no
frequency-mode=regulatory-domain mode=ap-bridge security-profile=
****** ssid=“********* By Mikrotik”
/ip firewall layer7-protocol
add name=torrentsites regexp=“^.(get|GET).+(torrent|\r
\n\r
\nthepiratebay|isohunt|entertane|demonoid|btjunkie|mininova|flixflux|\r
\n\r
\ntorrentz|vertor|h33t|btscene|bitunity|bittoxic|thunderbytes|\r
\n\r
\nentertane|zoozle|vcdq|bitnova|bitsoup|meganova|fulldls|btbot|\r
\n\r
\nflixflux|seedpeer|fenopy|gpirate|commonbits).$”
/ip hotspot profile
add hotspot-address=192.168.11.1 http-cookie-lifetime=3h http-proxy=
0.0.0.0:8080 login-by=cookie,http-chap,https,trial name=hsprof1
trial-uptime=15m/10m
/ip hotspot user profile
set [ find default=yes ] mac-cookie-timeout=3h shared-users=60
add name=dhcp_pool1 ranges=192.168.1.50-192.168.1.80
add name=dhcp_pool2 ranges=192.168.2.50-192.168.2.200
add name=dhcp_pool3 ranges=192.168.10.50-192.168.10.200
add name=dhcp_pool4 ranges=192.168.11.50-192.168.11.200
add name=dhcp_pool5 ranges=10.11.12.100-10.11.12.150
add address-pool=dhcp_pool1 disabled=no interface=ether5 lease-time=1h name=
dhcp1
add address-pool=dhcp_pool2 disabled=no interface=ether1_Service_Network
lease-time=1h name=dhcp2
add address-pool=dhcp_pool3 disabled=no interface=ether7-UBNT-WiFi_Front_Ap
lease-time=1h name=dhcp3
add address-pool=dhcp_pool4 disabled=no interface=ether8-UBNT-WiFi_Back_Ap
lease-time=1h name=dhcp4
add address-pool=dhcp_pool5 disabled=no interface=wlan1 lease-time=40m name=
dhcp5
/ip hotspot
add address-pool=dhcp_pool4 addresses-per-mac=1 disabled=no interface=
ether8-UBNT-WiFi_Back_Ap name=hotspot1_UBNT_Back_Ap profile=hsprof1
/queue simple
add burst-limit=3M/3M burst-time=10s/10s max-limit=2M/2M name=
queue1_Ubnt_WiFi_Front_Ap target=ether7-UBNT-WiFi_Front_Ap
add burst-time=3s/3s disabled=yes max-limit=10M/512k name=queue2 target=wlan1
add burst-limit=3M/5M burst-time=10s/10s max-limit=2M/4M name=queue3 target=
add address=192.168.10.1/24 interface=ether7-UBNT-WiFi_Front_Ap network=
192.168.10.0
add address=192.168.11.1/24 interface=ether8-UBNT-WiFi_Back_Ap network=
192.168.11.0
add address=192.168.2.1/24 interface=ether1_Service_Network network=192.168.2.0
add address=192.168.1.1/24 interface=ether5 network=192.168.1.0
add address=10.11.12.1/24 interface=wlan1 network=10.11.12.0
add address=10.11.12.0/24 dns-server=212.205.212.205 gateway=10.11.12.1
add address=192.168.1.0/24 dns-server=212.205.212.205,195.170.0.1 gateway=
192.168.1.1
add address=192.168.2.0/24 dns-server=212.205.212.205,195.170.0.1 gateway=
192.168.2.1
add address=192.168.10.0/24 dns-server=212.205.212.205,195.170.0.1 gateway=
192.168.10.1
add address=192.168.11.0/24 dns-server=212.205.212.205,195.170.0.1 gateway=
192.168.11.1
set servers=212.205.212.205,195.170.0.1
add action=passthrough chain=unused-hs-chain comment=“place hotspot rules here”
disabled=yes
add action=drop chain=forward comment=torrentsites layer7-protocol=torrentsites
src-address=192.168.10.0/24
add action=drop chain=forward comment=dropDNS dst-port=53 layer7-protocol=
torrentsites protocol=udp src-address=192.168.10.0/24
add action=drop chain=forward comment=keyword_drop content=torrent src-address=
192.168.10.0/24
add action=drop chain=forward comment=trackers_drop content=tracker
add action=drop chain=forward comment=get_peers_drop content=getpeers
add action=drop chain=forward comment=info_hash_drop content=info_hash
add action=drop chain=forward comment=announce_peers_drop content=
announce_peers src-address=192.168.10.0/24
add action=drop chain=forward comment=p2p_drop p2p=all-p2p src-address=
192.168.10.0/24
src-address=192.168.11.0/24
torrentsites protocol=udp src-address=192.168.11.0/24
192.168.11.0/24
announce_peers src-address=192.168.11.0/24
192.168.11.0/24
disabled=yes
add action=redirect chain=dstnat dst-port=80 in-interface=
ether8-UBNT-WiFi_Back_Ap protocol=tcp to-ports=8080
add action=masquerade chain=srcnat out-interface=Ote_Magaziou
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
/ip hotspot user
add name=admin password=admin
/ip proxy
set cache-on-disk=yes enabled=yes max-fresh-time=3h
/ip proxy access
add action=deny disabled=yes dst-host=:in.gr redirect-to=*********
add action=deny disabled=yes dst-host=https://facebook.com redirect-to=
google.gr
/system clock
set time-zone-name=Europe/Athens
[admin@MikroTik] >
