WinBox v3.27 released!
What’s new in v3.26:
*) fixed CAPsMAN service failure when viewing Radios table;
*) fixed Hotspot service failure when viewing Hosts table;
*) support Ctrl++ & Ctrl± on keypad for quick access to Zoom In/Zoom Out;
What’s new in v3.27:
*) fixed content drawing of read-only tables (introduced in v3.26);
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
Log window is showing no entries.
In CapsMAN under configuration I cannot configure a country anymore. It only says unknown and there are not options in the drop down list and I do not se anything under Radio.
I have cleared the cache and it did not help anything. Note that this might have been true under 3,25 as well. Saw this when I looked under Caps Interfaces and saw that country said unknown.
Edit: I have tested both 32 and 64 bit version and same issue + I also do not see anything under log.
Edit2: Sent all to support@mikrotik.com
File window is empty, too.
Log and File windows are empty.
also here, ccr1016, rb2011 and ccr1009 all shows NO log entries, same applies to files content.
Many thanks for a super quick response! All my issues are now gone!
CCR1009, rb2011 same problem, but CCR1036 - only file list empty
Thanks for a VERY rapid and successfully upgrade.
Respekt.
Log window empty
Anyone still having issues with blank windows/tables, please verify you are using WinBox v3.27 instead of v3.26.
Wow, that was fast! Thank you!
thx Mikrotik
Thanks will try it!
Good grief, I just downloaded 3.25 yesterday..
Anyway with 3.27 (64 bit version), file list and log are working on my RB750Gr3 and RB750r2.
Just tried to use 3.27 on a RB2011(current long term). I cannot add data to the firewall → NAT, each line goes blank when I highlight it..
I need to revert to an older version now.
Can’t replicate that on my RB750r2 with 6.47.1. Worked fine.
RB2011 ROS 6.45.9 (long-term), no problems with NAT rules.
Good grief, do you not check for updates at least twice daily??
