*) do not set hidden field values as empty when adding new item;
*) fixed Graphing and Quickset graphs;
*) fixed default value for disabled wireless EAP methods field;
*) fixed issue with showing non-existing values;
*) fixed managed list category grouping when value is IP with port;
*) fixed missing icon for submenus that are hidden by skin;
*) fixed neighbour table filter “all” storage;
*) fixed saving and restoring of filter comboboxes;
*) fixed skin behavior for “Add” buttons with dropdown;
*) fixed value updating when it is changed and disabled;
*) fixed values with required “&” prefix;
*) fixed wifiwave2 frequency field;
*) show error when not enough space to complete file upload;
If you experience version related issues, then please report them to support@mikrotik.com.
Humm, ok so it’s probably something on my end. I will have time later to test on other systems/software combinations to see what’s causing it. Last version (3.35) works fine.
I keep having issues with the position of some windows inside winbox. They tend to move to the upper left corner of the enlarged window. Sometimes its only the pppoe-out1 or lte1 and sometimes its all of the opened windows, they get all mixed up, one on top of the other. It happens on my ubuntu2204 with wine 5.0.3 and I thought it was just me. But I tried it on w10, too.
As a native linux user, believe me, no bug or lack of anything in winbox bothers me, but only one little thing: I am used (addicted) to the very fast copy-paste function of linux apps. Just selecting any text and middle-clicking is enough. Ctrl+c or Crtl+Ins and after Ctrl+v or Shift+Ins is killing me. Not to mention Select > right click > select “copy” > click elsewhere > right click > select “paste” and so on…
I know, this is up to the wine developers, not you. But I had to tell it somewhere! :=)
Last thought: well, you could compile winbox for linux!
Is it possible to make filtering by COMMENT case insensitive?
I often search some thing by comment. But if comment is, for example, “Printer”, but I try to filter “printer”, nothing will be found.
I guess filtering by comment must be case insensitive.
For those who experience problems with the new window functionality - it is also working just fine for us. Indeed it seems to be Wine related. Have you tried to upgrade Wine first and then test this functioanliy?
I am currently running wine-staging 7.9 with Winbox 3.36. When I try to open with “Open in New Window” selected it initially appears like nothing happens but then about 30 seconds later a window pops like router has been disconnected.
wine 7.7 here and new window thingy is broken. wine 7.10 has not landed on manjaro linux yet.
PS: what does “open in new window” actually? For me this looks like it forks another winbox process. When I tick the checkbox and hit connect the window flickrs for some 200ms. Nothing happens. Then I exit Winbox. After like 30 - 60sec suddenly another Winbox window appears and telling me it timed out to connect. Like wtf. I would suggest to avoid “cheap tricks”.
