Winbox via Parallels
I haven’t searched a ton, but haven’t found anything in this regard yet. When setting up a Tik for the first time from an Apple via Parallels(Windows 7) I can get on it the first time no issue via 192.168.88.1 - However if wipe out the default config. then you cannnot. Something happens with the MAC address translation from Apple to the Parallels system and it can’t see the TIK. Has anyone else experienced this and if so, what have you found to be a fix? Thanks!
I don’t have any problem. Do you have your parallels networking setup in bridged or shared mode?
Thanks for the reply - I have it set as shared right now.
Thanks, changed ethernet to bridged and can access w/out issue!
